ATF Fluid
Odor from the Canister for Crankcase Breather Valve(CBV)
Need Part # For Valve Cover Gaskets.!!
Taking a poll to see what type ATF everyone is using and how you like the brand you have installed... .
Especially interested in synthetic and +4 brands. I need to change mine but want to get the best I can.
Thanks guys,
Doug S.
Hey Doug,
I'm running Amsoil synthetic trans fluid. Had it in there since about 30,000 miles. After changing both differentials, transmission, transfer case, and of course engine over to synthetics, I gained about 1 mpg consistently.
Randy Jones, San Antonio, TX, rdj@gvtc.com, 98 1/2 QC, 4X4, American Racing BAJA's, 285/75/16, Amsoil throughout, Superstar 3000 export radio, Firestik antenna with fender mount, Fire-ring cable, Mag-Hytec Deep transmission pan
2000 VW Jetta TDI, auto, 45 mpg average
I think you forgot to post your signature which includes the year, model and other pertenant info.
I use LE - 1107 C-4
LE - 609 in diff SAE - 90
LE - 8800 SAE 15 - 40
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING, MAGNA MIRRORS onboard.
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
JNutter -
I spoke to LE about their transmission fluid, and it is currently not approved by Dodge, and they even went as far as to say that if I were to have any problems, the warranty for the transmission would be voided. That said, they are currently testing a fluid (I think it's their 7500) to get it approved. I too use their engine and differential oil, and thought they would have something for the transmission. If you've heard anything different, I would be interested to hear.
Y2K Quad Cab SWB 4X4, White (aka: The "Iceberg"), Auto, 4. 10, Leather, Loaded, Line-X, KNAACK Crossbox, Smittybilt Nerfs, BFG 295/75-16's, DC Bug Guard, Rancho 9000's.
Doug..... I'm using Mopar ATF+4 'cause that's what Bill K. and Darin told me to do after the first thousand miles on the TC and VB.
Be warned... . it's not available anywhere but through the dealer... . that I know of..... and it's $30 a gallon #ad
White 2001. 5 2500 ST, SWB, 4X4,QC, AUTO, 4. 10's, LSD, 285/75/16 On Weld Outbacks, PIAA 510's, Line-x, Tinted glass, Redline 85+, Blow-by-bye, RE-0880 & 25-0880,muffler fell off,level truck with 2" tuff country kit, Bilsteins at the corners, Di Pricol egt and boost, Mag-hytec "original flavor" transmission pan and Dana 70 diff. cover, Westin Step Bars, Custom Plate 24V-DSL
Ditto, though I only switched at 85K miles. 5K miles so far and no problems. And I didn't need friction modifiers in the diffs.
Fest3er
Have had the Amsoil ATF in transmission since truck had 8,000 miles, it now has 130,000. No problems. Mine does not require the +4 specification, but the Amsoil ATF does meet that specification. I did remove the fluid when I installed a Mag-hytec pan, but re-installed after installation. Did an oil sample at that time, and the report came back as "continue use".
Wayne
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
Wayne Owen
Do I need the +4? I just bought some +3 for an upcoming change. My manual says +3, but is there new info?
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; BedRug; Forest Green; Isspro Pyro, Boost, and Trans Temp Gauges; 27' TT
I am using AMSOIL Synthetic ATF. The best benifit is a major drop in operating temperature. At least a 15 degree drop solo and same when towing. I am also using MagHytecs deep trans pan.
A friend has my old '95 Ram and switched to AMSOIL ATF. He is seeing the same temp drop with the stock trans pan.
Amsoil was installed by the dealer when my trans was REPLACED at 128,000.
'94 3500 4x4, 210,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"I am my own performance station"
