Diesel goes in the fuel tank and ATF in the automatic transmission. Modern ATF should not be run thru a modern IP. Do a seach and read all night. SNOKING
I agree!
And to further the flame responses: Propane is for BBQ's, alcohol is for drinking, nitrous is for dentists, and gasoline is for washing parts.![]()
Paul
I agree!
Paul
propane is not for a bbq
as for the atf no beuno in the fuel tank though it does clean the injectors
At what cost to the operation/health of the VP44????? SNOKING
You guys are missing another potential problem
Red Atf + diesel fuel = red diesel = huge fine $$$$. :{
Negative. That is a non-issue. The dye that they test for is not the dye in ATF. ORD dye is a very specific dye and is only used in untaxed and high sulfur fuels, and they don't do a color test. They do a test for the specific chemical (Solvent Red 26 or 164) that causes the color change.
I understand that however why give them a reason to dig deeper? Around here they dip the tank, if it's not red they don't need to test it. If it is, they get out the chemstry set. Especally since the whole ATF in fuel being a benifit is just an assumption. There are alot of products that can be used as a lubricant, most of which should not be added to fuel.
