Richard, I see some of your points, what Im trying to say is that if your making 50psi with a good single and 50psi with a good set of twins the air intake will be cooler from the twins at the same boost point because 50 psi for a good single is at the end of its efficiency whereas the twins are barely working and the compounding effect is more efficient in terms of keeping each turbo within its compressor map efficiency. Does it take more HP to drive twins? Alot of people could argue this but how much HP does it take to drive a single? Not much, so twins not much more. Yes more but not much since exhaust is WASTED thermal energy, backpressure should be the culprit here and what are the drive pressures for good twins and singles at over 50 PSI? If we were supercharging them thats a diffrent story.
If you are such a believer in singles why did you say that, "putting on twins will be quicker in the 1/4? Also you better hope that Wade (diesel power) doesnt read this because he may bad mouth your 800+ HP #'s on diesel only because he thinks he has the only one.
Richard, Im not bad mouthing or badgering anything about you or your way of doing things, Im just wanting to learn things. Im still fairly young and have a passion for this stuff. Could you tell us more about your truck and how its set up? You say you pull alot with it and I have a harder time doing that with the surging issues on the 66. What turbo? How many lbs of boost? pump mods, injectors? I hope youll be willing to share your set up with us so we can learn something from it.
