Well, whatever works and holds the corrrect torque.
What is the correct torque anyway? I think the OEM bolts were 32 ft #. That pushed my first set of studs way into the plastic range. Then I found out that the torque for my configuration should be 16 ft #.
What torque is right for the ATS cap bolts? Has anyone actually figuered it out? Are the cap bolts really bottoming out?, has anyone actually measured them?
There is an equation for the elastic limits for bolts and has diameter, length, kind of materials, what you are trying to hold and its thickness, and kind of materials, and temperature range, and what the prestress of the holding device is and I don't know what else that feeds the equation.
I know where I got my figuers and why I did what I did. Someone else will have to figuer it out to whatever their configuration is. I do know there are still threads like this one about the ATS cap bolts not holding torque. Now the question is WHY?
Mine stay put, all 12 of them, and at the torque I set them, and they were checked after 3 months and will be checked again after 6 months.
Like I said at the first, whatever works.
Bob Weis
