ATS manifold questions
new combo guage deal
Mudflaps
I didnt want the standard finsih to flake off so i choose the 2000 series, I didnt want to do it twice is what am saying... I have to admit the Sterling silver is the more glamous of the two. One the sockets. . mine came back with a special tape on the two outer sockets to prevent the coating on those sufaces. The inters were coating and i buffed them out with emery paper on an end of a drill. They were still tight, so i put the 2 outers in the freezer for 2-3 hours and presto... . nice fit... JB
I called Jet-Hot today to arrange for coating my manifold. They suggested that the 2000 series was better at preventing oxidation so that is what I am going with. They do the 2000 coating at the Pennsylvania and Mississippi locations only. Memory is failing me but I believe they said lead time is running about eight days.
Anyone hear of High Performance Coatings? They are in Ca. , and Ok. City, Ok.
I had the headers for my V-10 coated by them. It kept the temps. down in the eng. compartment. Don't know what it would do for the ATS.
Larry
Sasquatch, can you enlighten those of us less mechanically inclined as to why your egt cool down process was shortened by adjusting the valves? How far out of spec were your valves? Thanks
BZIN/UL,
When I had the valves done, the mechanic told me that the exhaust valves were very loose (an average of . 003") and the intake valves were consistently tight by about the same margin. I couldn't tell you why that's the case, and can only conclude that the valves were misadjusteded when we swapped out the valve springs the day the BD exhaust brake was installed.
All I know, for sure, is that I noticed a marked reduction in power after the BD brake was installed, and a buildup of heat (higher EGTs, during hard pulls) and longer cool-down times. I concluded that (despite what Scott Dalgleish's, TDR review claimed) the BD brake was contributing to exhaust back-pressure, and thus creating the related performance/heat issues.
I'm not an automotive engineer, or professional mechanic, so I'm not going to embarrass myself with lame forays into the realm of internal combustion. I just know that we adjusted the valves and the power was back, big time, and the engine ran MUCH COOLER! (and cooled down, therefore, MUCH FASTER)
Maybe somebody else can put a finer point on your question, and offer a more comprehensive explanation. I'm sorry I'm not up to the task!
Thanks, all, for the information and links to get the discount on this manifold.
For those of us in the Atlanta area, there is a local shop that does really wonderful work with powder/heat paint and ceramic coatings on anything and everything you can think of. The name of the business is "Miller Power Coating," and they have done some work for me in the past. They also handle all the show trucks, Harley-Davidson, and Hot-rod work in the Atlanta area. I've been through their plant and seen the sand blasting, ceramic bead tanks, ovens and other aspects of the operation. They use the same coatings and procedures used by Jet Hot, and guarantee their work.
I talked to Bill Miller (owner) and he said that they'd ceramic coat the manifold for $125 and have it ready for pick up inside a week at their facility.
They use the same silver product and Billy (Bill's son) told me that the material is guaranteed to internal, exhaust gas temps of 1600 degrees, and external manifold temps of 1350 degrees. He said, "If you reach that temperature, you've toasted your engine, anyway!" He also has a 2000 degree silver coating but said that it's a ***** to spray (didn't elaborate) and is more expensive. He has the blue/black, which he said has a "flat" appearance, and doesn't look as nice, or go as well, with an engine compartment full of chrome. His race customers HotRod, "Road Atlanta" types who run their trucks (fuel-flooded and hot) all the time, experience a dulling of the ceramic coating (from bright "chrome-look" to a dull silver appearance) over a period of several years. But, he added, the coating remains intact and looking VERY GOOD.
The number for Miller's is: 770-931-1505. I don't think they want to mess with out-of-state work, but that's just a guess. They stay pretty busy all the time.
I dropped off an ATS Exhaust Manifold at Airborne Coatings today.
Below is a sample picture of the finish:
Having the Aluminum Ceramic exhaust coating done, INSIDE & out. I asked the owner if they spray the inside on a turbo charger exhaust manifold. He said "no problem". I guess they are confident the finish won't flake off.
They say the product will hold up fine at 1200° continous. 1500° intermitent. Minor discoloration over time is not a concern for me.
Total was $75. 00. I was expecting double that. #ad
More Info : http://www.airborncoatings.com/customer/index3.html
[This message has been edited by HEMI®Dart (edited 03-28-2001). ]
We just got one back from Jet Hot with the Jet Hot 2000 coating and we had to hand sand the coating off the mating surfaces in order to get the manifold pieces to fit together correctly. I'd avoid coating them in the future. They do have to move with expansion/contraction and that is really the whole purpose of this manifold. It mimics the ones found on big rig engines where there are multiple cylinder heads and they have to have multi piece exhaust manifolds due to the heads moving around under boost. That's why ATS recommends putting anti-sieze on the mating surfaces.
Chris Timochko
*Association of Diesel Specialists Certified*
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Rhino Linings, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. 15. 50@97mph on Goodyear All-Terrain tires.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission. 11. 54@115mph
Hemi, that looks EXACTLY the same as the Cermachrome finish I mentioned in another ATS exhaust manifold post. The problem with this coating is that it is said to be rated at 1300 degrees F. I've seen a 12v ATS manifold with this coating deteriorate, mostly at the outside bends of exhaust ports #1 and #6. I also noticed corrosion spots forming beneath the ceramic coating (that actually started to show through). #ad
The owner of the manifold with the Cermachrome finish has since decided to get it refinished under warranty (3-year) except, this time he is going to have them apply the 2000 degree F. coating... probably the matte black.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
Couple' of notes on the ATS. I had mine done by Jet Hot in the series 2000 black. 1. It only took a few seconds to clean up the overspray with scotch brite. 2. I found out that antiseize will quickly smudge things up! 3. One of the bell connections was a little looser than the other. I thought that it would tighten up over time with carbon but it still leaks a little.
