I have about 25k on the truck now and I am looking to change my rear axle fluid with 75W-90 synthetic per American Axle recommendations. I have also just recently noticed a whine from 65-70 MPH on a slight pull, goes away on hard pull or coast. While the cover is off I am going to do a gear pattern check to see what I have to do to correct the whine. From my past dealership technician experience, a gearset does not audibly whine if the gear contact pattern is correct. Usually, if the pattern is off center concerning tooth contact depth, I have found that changing pinion depth will correct the issue. In the other direction concerning where the pattern is located between the ID and the OD of the ring gear, then adjusting backlash usually brings the pattern where it needs to be.
I have a shop manual on order but not in my hands yet. I was wondering if someone here has had some experience with the method of adjustment for setting backlash on the 11. 5" American Axle before I take the cover off. I am hoping there are some threaded collars instead of shims behind the carrier bearings. If the American Axle has some sort of threaded adjustment and if all that needs to be done is a backlash correction, then the correction shouldn't take long at all to do.
However, I have run into Ford and Chevy gearsets in the past where you can get a good pattern on one side of the teeth but not the other. In cases like that you have to comprimise on the best pattern you can get or try another gearset. Sometimes you you only end up moving the noise to a different speed. Hopefully I won't run into that problem.
