The problem im having is it ignites for about 5 seconds then turns off flame, while blower still going, then it ignites again for the same amount of time with same result.
It could be the limit switch which i located its mounted belowfurnace area and impossible to reach without removing blower moter, i can see switch when removing air duct inside camper, but can barely reach with long screwdriver. I believe on this model that this limit switch reads heat, but can also kill flame if it thinks there no heat in order to stop free gas flow without a burn. But its probably just the igniter/flame sensor, i will check it out when i get a chance. thanks guys
