Engine/Transmission (1994 - 1998) Auroura 2000 turbo/HTB or Hybrid
Engine/Transmission (1994 - 1998) 300 VS 370 injectors
Engine/Transmission (1994 - 1998) DDP4's vs 370's injectors
Was looking to upgrade my turbo. Check out my sig. Pull a 9000# boat now up some long grades. Want the least turbo lag, the lowest egts, and the most power/airflow I can get. Got the banks plate in now 265hp/696TQ with 4"mbrp exhaust,3GSK and would like to put in the tst#10 plate if I can get my egts low enough. Any turbos out there that would do a much better job than my 14cm housed HX 35 ?
the HTT HTB2 62/12 combo is a great towing turbo, spools fast, probably faster than the HX35/14 combo, and will provide more than enough air for what you have, even with the 10 plate.
wes
Check out my signature, the 01 I tow 13,000 with. As long as I keep the RPM above 2000 rpm I can run 6th gear all day long. I have the 3. 54 gears. ON the interstate I run 6th. At around 50-65 mph I usually run 5th. Matt did you get your transfer case swap done?
Not yet. Actually I can't seem to figure out whether it's the transmission or the T-case thats the problem. I put it 370's the other day, so I'm putting even more power to them... . still hasn't blown up yet! :cool:
I have a #10 in mine with the 35/16 and I have no trouble at all keeping it cool. Heck, Last year I was towing 16-20K lbs at least once a week and it would stay cool as long as you didnt lug it.
I pretty much do like zstroken said, but I stay above 1900. If I drop below 1900 with any more than about 6Klbs, I have to put it in 4th.
I would think the hybrid would be plenty for JUST a #10, but not much more towing. But if you plan to do more to the truck, then go with the 62.
-Jeff
High tech turbo told me the HTB2 would spool fast with 425 HP,Which I dont have. They said the HTBG may work for me. 325 HP to 450 HP Can upgrade to a HTB2 if needed. ATS tells me the Aurora 200 works so well it does not need a wastegate. Has a 3yr 150,000 mi warranty No wastegate to stick open is nice. Hmmmm..... :rolleyes:
Thanks for the imfo. I will e mail High tech and see what they think of the HTB2 62/12 combo. I wonder what the drive pressures are like with a 62/12cm. I'm new to this,But doing lots of homework. After I bought that Banks fuelplate anyway. extra 100. 00 for there plates.
