I've got a question for you guys with Auto Meter FP guages. When I first got mine installed (had the plastic sending unit) it worked great for the first 30min-30miles, the needle was ROCK steady then it developed a slight bounce in the needle. I drove it like this for about two weeks until the sender went bad, it was leaking. So, I got it replaced with the new metal one, no leaks since. When the metal one was installed, same thing, the needle was ROCK steady for the first 30min-30miles. After that the bounce was back. So the other day after I changed my fuel filter I again experienced the same thing. My guess is that after the fuel system is drained and re-primed air is getting in there somehow.
The sending unit is mounted on the firewall horizontally. I have tried to bleed it while the motor is running by cracking the line open at the sending unit but the bounce is still there. I'm thinking of putting the sender in a vertical position so that it might bleed more efficiently. Does it sound like I'm on the right track?
