I have an 2003 Everest 5th wheel. When I deploy or take in the slides, the pump will stop and the switch is dead for 10-20 seconds, and it seems to be getting worse. It might take 5 or 6 attempts to put out/take in the slides. The owners manual for the slides shows a wiring diagram for an automatic resetting fuse, that must be installed within 18 inches of the battery on the hot wire of the pump motor. I suspect this fuse needs replacing, but I'll be darned if I can find it. It is supposed to be in the cable that runs from the pump motor to the battery. The pump, motor and batteries are all in the same compartment, and the only fuse I can find is for the front jacks. Any ideas?
Thanks for your help.
