I didn't know this and haven't seen it anywhere, but you can set the tow mirror memory setting for when they are up AND down. You have to have drivers seat memory for it to work. Look in the owners manual for setting the memory of the seat, peddles, mirrors, station presets, etc.... after you have them set and saved with the mirrors down flip the mirrors up and set them in the desired position and then hit set again. make sure nothing else gets changed while you are doing this. I have tried this many times and it works. Flip the tow mirrors and hit 1(or2) button, or keyfob, if linked, and the mirrors will move to the up setting you programed. Flip them back down and het the 1 (or2) button, or keyfob, and the mirrors will go back to the setting you made when they where down.
DRIVER MEMORY SEAT — IF EQUIPPED
Driver memory seats allow the driver to recall settings
for the adjustable pedals, mirrors, seats and the radio
presets using the key fob.
The memory seat buttons are located on the outboard
side of the drivers seat cushion.
The memory buttons 1 and 2 can be programmed to
recall the driver’s seat position, driver’s outside mirror
position, adjustable brake, accelerator pedals position,
Automatic Temperature Control (ATC) temperature setting
and radio station preset settings. Your Remote
Keyless Entry (RKE) transmitters can also be programmed
to recall the same positions when the UNLOCK
button is pressed.
NOTE: The power lumbar option is not programmable
with driver memory seats.
Your vehicle was delivered with two RKE transmitters.
One or both RKE transmitters can be linked to either
memory position. The memory system can accommodate
up to two RKE transmitters, each RKE transmitter linked
to either of the two memory positions.
Setting Memory Positions And Linking RKE
Transmitter To Memory
NOTE: Each time the S (SET) button and a numbered
button (1 or 2) are pressed, you erase the memory settings
for that button and store new settings.
1. Turn the vehicle key to the ON/RUN position.
2. Adjust the driver’s seat, recliner, and both sideview
mirrors to the desired positions.
NOTE: Not all motors may be moved at one time. Refer
to “Power Seats—If Equipped” in this section for further
information.
3. Adjust the brake and accelerator pedals to the desired
positions.
4. Turn on the radio and set the radio station presets (up
to 10 AM and 10 FM stations can be set).
5. Adjust the Automatic Temperature Control (ATC)
while the ATC is in Auto mode.
6. Press and release the SET button located on the
driver’s seat.
7. Within five seconds, press and release MEMORY
button 1 or 2 on the driver’s seat. The next steps must be
performed within 10 seconds if you desire to also use a
RKE transmitter to recall memory positions.
8. Turn the ignition OFF and remove the key.
9. Press and release the LOCK button on one of the RKE
transmitters.
10. Repeat the above steps to set the next memory
position using the other numbered memory button or to
link another RKE transmitter to memory.
Memory Position Recall
NOTE:
• The vehicle must be in PARK to recall the memory
positions.
• Not all motors may be moved at one time. Refer to the
“Seats/Eight-Way Power Seat” in this section for further
information.
To recall the memory settings for driver one, press
MEMORY button number 1 on the driver’s seat or the
UNLOCK button on the RKE transmitter linked to
memory position 1.
To recall the memory setting for driver two, press
MEMORY button number 2 on the driver’s seat or the
memory position 2.
A recall can be cancelled by pressing any of the
MEMORY buttons on the driver’s seat during a recall (S,
1, or 2), or pressing any one of the power seat buttons,
pressing the adjustable pedals button, or pressing either
the LOCK or UNLOCK button on the RKE transmitter
when not in the ignition switch. When a recall is cancelled,
the driver’s seat and the pedals stop moving. A
delay of one second will occur before another recall can
be selected.
NOTE: A chime sound may be heard if setting memory
was inhibited for any reason
button is pressed.
information.
positions.
driver’s seat.
transmitters.
NOTE:
positions.
information.
memory position 1.
memory position 2.
be selected.
