I just finished installing an ISSPRO turbo temp monitor on my '98. 5 24v. This is a really neat product - it monitors a post-turbo thermocouple (it can daisy chain off of an existing one if you mounted your's post-turbo) and doesn't let the engine shut down until the EGT is below a set temp (comes preset at 300 degrees and you can adjust it from there). It was a little tricky getting it hooked up as Isspro doesn't have vehicle specific instructions. At first I had it wired into only one of the ignition wires and when I turned off the truck ABS and Air bag alarms went off (they are fed off of a different bus). So I had to design a circuit with a relay and a diode to power up the second bus. It now works GREAT!! An added benefit is that I put an exhaust brake on last weekend and now I can start the truck, turn on the exhaust brake, wait about 15 seconds for the post-turbo EGT to get over 300 degrees and then turn off the ignition and pull the key, lock the doors and walk away for it to warm up at idle (takes about 4 minutes to come up to full operating temp in 30 degree weather!) (Don't forget to leave the truck in neutral) When I want to shut down I just turn off my exhaust brake, set the parking brake, turn the truck off and walk away. She turns herself off when she's cool!! I also installed a disable switch on the right side of the steering column right behind the ignition switch for an emergency shut down - turn off the ignition then hit the switch. I'm attaching pictures of the install plus the schematic that I drew. This schematic is out of the factory service manual on page 8W-12-6 (in the 98 manual) - it's the very first schematic in the 8W-12 junction block so you can compare to the schematic and wiring colors in your truck. This setup is much better than the diesel life saver through genos (it's just a timer) and it's cheaper too! Here are the total costs:
(I bought most of the stuff through diesel injection service except for the relays, wires, fuse holders, etc. which I bought through a local electronics supply shop and these prices do not include shipping)
ISSpro turbo temp monitor (R4130) $116. 64
K type thermocouple (R658) $27. 34
Lead wires (R660-10) $10. 29
R51-1D40-12F 40A-12VDC relay $5. 72
NTE5983 100V 40A Rectifier $5. 00
small plastic project case $2. 00
(to house rectifier)
2 automotive style fuse holders $1. 84
20A switch $5. 00
2 20A fuses (had on hand) ~$1. 00
10 gauge and 14 gauge wire $4. 00
$178. 83
-Steve St. Laurent - President of the Great Lakes TDR
'98 Quad Cab Long Bed (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, Prime-loc remote fuel filter,
boost & pyro gauges, TST Powermax, muffler eliminator, 5" chrome tip, BD Exhaust Brake,
Isspro turbo temp monitor, Permatech spray in liner, Grizzly stainless nerf bars,
Stull SS grill & bumper inserts, Front Draw-Tite receiver, BFG 285/75R16 AT KO's
http://my. voyager.net/stevest
[This message has been edited by Steve St. Laurent (edited 03-29-2000). ]
[This message has been edited by Steve St. Laurent (edited 03-31-2000). ]
[This message has been edited by Steve St. Laurent (edited 07-20-2000). ]
20A switch $5. 00
$178. 83
