Auto shutdown based on EGT up and running!
Ram Tow Hooks-Help
Uniden PC78LTW
Steve,
Suggestion's on your wiring. I am in the process of installing my ISSPRO turbo shutdown monitor.
I am installing relay in PDC for ST-RUN A21 junction block (see 8W-10-20 and 8W-12-6); same type as Trailer Tow relay. Power from joint connector number 2 in PDC, cavity 14. Circuit is fuse 8 Trailer Tow; 40 amps. Output/splice to A21 10 DB. Relay trigger from ISSPRO shutdown monitor ignition switch circuit. Using 10 gauge wire for this circuit.
ISSPRO shutdown monitor is wired to power RUN A22 junction block (see 8W-10-20 and 8W-12-6). Power/splice from fuse 2 ignition, 30 amps, A2 14 PK/BK. Output/splice to A22 14 BK/OR. Using 12 gauge wire for this circuit.
No additional fuses required. Additional relay installed in PDC.
If you need to force shutdown, pull fuse 9 in junction block.
2001 ETH/DEE...
