Auto Start or Turbo Timer
Detroit Locker
summit headlite kit + fisher module?
I called Aspen Sound in Boise and they carry the Compustar systems. They guy was saying that is has an automatic turbo timer.
About $600 installed. I'm not sure how that price relates to other prices??
I was thinking maybe just doing the remote start and not the alarm, which would be less $$
Viper (791XV?) is specifically made for diesels and has remote start and a turbo timer that can be adjusted. It's also a good alarm; I own two of them.
Dave
I just put in the Clifford Matrix RS 2. 1,I got it for $239. 00 from the local car audio shop.
I installed it myself and it was really easy,took my 2 hours start to finish. I did not hook up the siren or shock sensor as I dont need/want those features. . If you wanted to hook those up your talking another 10 minutes
It has the remote start with run times from 12-24-40 minutes. I have it set on 12 minutes.
Just push the button and she starts(after the light goes out)the truck stays locked till I pop the doors with the remote. Just put the key in and turn it,step on the brake and you are good to go... This system has the anti grind function so if you turn the key to far the starter will not engage. . Also if you press the brake before the key is inserted the truck shuts down.
It has the turbo timer with 1-3-5-9 minute runs times. I have it set on one minute cool down.
I just hit two buttons on the remote(with one finger) and it does it's thing. Once out of the truck I hit the lock button and its all secure.
It has a run while out of the truck function that will leave the truck running for 24-40 minutes. I have that set on 24 minutes.
Same drill just push two buttons and it will run for the pre-set times
