fox said:Bill K has talked about this a long time ago.
The clutch area in the torque converter is already larger than the front and rear clutches. Simply adding area to a clutch that is already large enough to not be a problem doesn't cure anything.
Production tolerances need to be addressed to save the trans.
This is what I believe he said.
These trans have three bad area's .
1 ) torque converter is way too loose.
2 ) line pressure is too low
3 ) production ( mass production ) is sloppy.
So, look at it this way.
Using a bigger chain to pull the truck out of some mud will do no good if the clevis pin is a 1/4 inch bolt!!!!
Anyway, buy what you want.
The clutch area in the clutch packs compared to a single disk converter is not a valid comparison.
After market trannies have extra clutches in the packs. When replacing only the valve body and TC the line pressures are increased to maximize the holding power of the stock clutch packs.
if you have a 5 disc pack increasing the line pressure 5% will give ~25% more holding power (5% more force per disc). 5% increase in pressure on a single disc gives only 5% more holding power.
So, even if a clutch pack has less total area it can hold more force than a single disc TC.
ATS did an exceptional job of explaining the concept...
http://www.atsdiesel.com/home/triplelok.asp
http://www.atsdiesel.com/atsu/atsu-lockupclutch.asp
from ATS's web site
Introducing TripleLok®
Many of our competitors also realized the torque converter problem and began trying to beef up their torque converters with more clutch surface area, hoping this would provide more holding power. A torque converter with more surface area will wear longer, however, it doesn´t necessarily reduce slippage or transfer your power to the ground. It depends greatly on how the surface area is being added. Go to ATSU Lockup Clutch section to learn more about lockup clutch surface area. With competitive designs the only way to increase static holding force (and thereby reduce slippage) is to increase the normal force by applying increased line pressure.
We liked the idea of a larger lockup clutch surface area to minimize wear, but didn´t want to have to use extreme line pressures or additional hardware to increase the static holding force. Our solution was to utilize the concept of a clutch-pack, which is used throughout automatic transmissions. By using a clutch-pack, the lockup clutch surface area can be increased without the need to increase line pressure.
With our clutch-pack design, the surface area is in three distinct planes giving THREE times the holding force of other torque converters. This is really important because having a robust lockup clutch system allows us to also optimize the design of the stator to match the torque curve of your engine and give you high torque multiplication. Other torque converter designs require the stator to be operational over a much larger speed window because the clutch system won´t lock up at low speeds. The stator in TripleLok® is designed to get you off the line with power, then to get out of the way for lockup at 30 mph. By using a stator design with high torque multiplication and a stall speed matched to the turbo diesel, and getting into lockup as soon as possible, we have the best of both worlds; good acceleration when pulling heavy loads and 100% efficiency with the early lockup.
