Anyone ever experience the shift lever feel like it doesn't want to leave the Park position? It almost feels like you parked on a hill with the weight of the truck on the parking pin. It takes quite a bit of effort to move the lever out of Park. When it does move the bind releases and makes a loud clunk. Doesn't seem to be a driveline clunk, sounds more like the the auto transmission linkage freeing up. The same noise can also occur going from Reverse to Park. Doesn't happen all the time. It is much worse when moving the lever slowly into or out of Park. Doesn't seem to be any slop in the driveshaft / rearend. Are there any adjustments and/or lube points for the linkage? Other than that, transmission operates same as always.
Thanks,
Dave D
2001. 5 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod, Westin CPS Platinum Step Bars - Black on Stainless
[This message has been edited by Dave D (edited 02-08-2001). ]
Thanks,
Dave D
