Engine/Transmission (1998.5 - 2002) Auto transmission - bind-up, then no O/D or TC lockup
Engine/Transmission (1998.5 - 2002) Will I need a turbo upgrade?
2nd Gen Non-Engine/Transmission Worn Steering Wheel Cover
Cruising around today, doing about 75MPH, then let off the throttle while coasting down a hill... part way down the hill, my transmission locks up (as in chirps the rear tires :eek: ), then drops to 3rd gear, no TC lockup, and been there ever since. I was 20 miles from nowhere, so I had to limp it to the nearest town.
So far, here is what I found:
Truck feels like it's dragging when taking off. . like it's in 2 gears
transmission is full of fluid, fluid is clean and smells ok.
Got a code P0753 -- 3 / 4 shift solenoid / Relay circuit
Truck currently has NO O/D or TCC lockup
Can press O/D off button, but no RPM change, no lockup. 3000 RPMs @ 60MPH :mad:
So, where is the 3/4 shift relay? Solenoid? Could this cause it to hang in two gears at once? I need help guys... I'm stuck.
FIXED IT!!!
3/4 shift solenoid (O/D solenoid) was deader'n a doornail :(. Several phone calls and $110 later, I'm back in business. I'd like to thank Inarush76(James) for his wisdom and extreme patience in the matter! The phone tag game is starting to get fun :p :rolleyes: Sorry about all that ;) I'd also like to thank Jim Fulmer for the referral!
THANKS GUYS!!!!!!!
