Auto Transmission HTO query?
Help installing BD 2low kit
Diesel Insulation Product Coming Out at Dieselfest
<font color = blue > It's been brought to my attention by Andy Perreault in another forum, that PTO driven air-compressors on tire service trucks which change flat tires on 18 wheelers are pretty common (in the USA). Only problem, I'm currently in Europe.
Do any TDR forum members/visitors know of any heavy truck servicing companies primarily in the Simi Valley, California area that either supply the industry or modify pickups into service trucks? I'll also consider further afield if there's no luck on my own doorstep.
Cheers
JMc
2001 3500 QC, Sport, SLT+, 24v Cummins, 4X4 dually, Auto 3. 54/LSD, Long Bed, Red exterior w/Agate leather, all factory options, Line-X bedliner & underseal, Firestone Airbags, RS9000s, Reese class 5, 60 Gal Aerotank.
on the note of the electric compressor, you could install a Aerogen generator under the hood next to the alternator and it is capable of 6kw at any engine RPM, it is about $3k but would be a simple solution also, I think TST sells this kit, I know they are very reliable though, the military has decided they are good enough for their uses.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights, Diesel Dynamics Stage-3's, DD Boost Module,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed.
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz. 20m.com
Add on's to come: Exhaust Brake, Torq-Loc, Line-X bed-liner, and any other Ram Runner required modification...
