auto transmission upgrade allison 643?
McLeod Clutch Info?
Prime-Loc System
therabbittree
hey i have a 89 first gen with 727 transmission. . its strong but has no over drive and no locking torque converter ... . so no e brake and no more then 75-80 mph. . so i was thinking better auto either a allison 643, as it locks up . . or a dd auto trans built up from newer dodges... mummn 643 is much cheaper. . any one know specs on these?... are they overdrive?... lock up all the tim eetc. . i guess if i did the allison i'd have to divorce my 205 transfercase... any ideas???thanks
later
deo
\x/ hillfolk!
Call or email...
DTT, Bill Kondolay, and he will give you the info you need. He builds his version of the 727/47RE which is practicaly bullt proof, and no engine match-up problems. You will, however probably have to move your transfer case back to accomodate the longer overdrive transmission. Not such a big deal for what you will end up with.
Ron
Allison
While Allison makes several excellent transmissions and the MT643 is one I don't think that it would be a good choice for
your Ram. For one thing it is not an overdrive transmission, for
another it is a much larger transmission than you would want to deal
with, 478 lbs. dry. It is made to bolt up to a SAE #2 housing.
Depending on the A/N it can have one of 5 different torque
convertors with ratios at stall ranging from 3. 04 to 1. 82 to 1.
The ratios in the trans are as follows: 1st 3. 58, 2nd 2. 09, 3rd
1. 39 and 4th1. 00, reverse is a nice deep 5. 67 to 1.
What about that transmission that the Germans want to put into new Dodge trucks I think it's a six speed. The article is in this quarters TDR magazine.
