It mostly depends on how YOU use your truck, any heavy hauling or towing and the trany will fail. I think the stock trany is marginal at best, and that is with a stock Cummins. One thing you should avoid is trying to solve your problems by adding small and cheap additions in the hope that they will magically solve your problems. Only thing they will do is lighten your wallet and put you further away from a real workable fix. BD and many others must make a fortune on people like yourself that are hoping for an inexpensive fix to their transmission troubles. It would be nice if it would work, but unfortunately their is no cheap fix to the problem. The logical thing to do would be hold off of any engine up-grades till you can afford a new trany. It does no good to replace any one piece, they are work with and upon each other, so do yourself a favor and wait till a complete job can be done. If you simply can not do with out you injectors, just don't tow or haul anything heavy and be gentle. The sad part is everyone wants to talk about big HP numbers, what new parts have been installed on the engine. Truth is you can add 150 HP to your truck and never fell it's effects, the stock TC is a DOG and simply does a lousy job of transferring power. No matter what numbers the engine runs(HP), the TC will simple jump to 24-2500 on take off and the truck will waddle off from the start. The best mod you could ever make to your truck, would be a Good after market trany and TC. I probably wouldn't have believed it myself before the ATS install, but it is true. The engine doesn't just jump up in RPM, now it stays much lower and you feel the power getting to the ground. I think you could take a stock truck with a good trany/TC combo, and dust a truck running 100 more HP but thru a stock trany/TC combination. What ever you do, make sure you do it right and good luck.
