BOstiguy said:This worked on my 01, hope it helps...
Remote Keyless unlock all doors on first press:
1. Same as 1 & 2 above.
2. Press drivers door lock switch to UNLOCK the doors then to LOCK within 30 seconds.
3. You'll hear a single confirmation chime when programming is completed.
AKaiser said:This one I would never do, as the "driver door unlock on first press" feature is a security feature to keep someone from jumping in the right side of the vehicle that you didn't see. It's so simple to "double-tap" the unlock button anyway, why mess with it?
Joe Mc said:OK, how about on my 99, as far as the "Unlock both doors on single press of unlock on remote", it's always unlocked both doors w/single press. I'd like to change function so it will unlock driver door on single click and both on double click.
Can this be done?
BOstiguy said:Try it and find out, you can't do any harm.....
also I believe this info may be found in your owners manual.
