2nd Gen Non-Engine/Transmission automatic door locks
Engine/Transmission (1994 - 1998) Exhaust question
Engine/Transmission (1998.5 - 2002) 2001 block heater
This worked on my 01, hope it helps...
Automatic Door Locks at 15mph (on/off)
1. close all doors
2. place key in ignition and cycle from off to on postition 4 times leaving it in the ON postition (do not start)
3. Press the drivers side door lock to LOCK to lock the doors within 30 seconds.
4. You'll hear a single confirmation chime when programming is complete.
5. repeat to toggle this feature.
Remote Keyless unlock all doors on first press:
1. Same as 1 & 2 above.
2. Press drivers door lock switch to UNLOCK the doors then to LOCK within 30 seconds.
3. You'll hear a single confirmation chime when programming is completed.
Horn Chirp ON/OFF:
2. Press and hold the UNLOCK button on the REMOTE for 4-10 seconds.
3. Press the LCK button on the REMOTE and then release BOTH button.
4. You'll hear a single confirmation chime whe programming is complete.
This one I would never do, as the "driver door unlock on first press" feature is a security feature to keep someone from jumping in the right side of the vehicle that you didn't see. It's so simple to "double-tap" the unlock button anyway, why mess with it?
OK, how about on my 99, as far as the "Unlock both doors on single press of unlock on remote", it's always unlocked both doors w/single press. I'd like to change function so it will unlock driver door on single click and both on double click.
Can this be done?
Can this be done?
Try it and find out, you can't do any harm.....
also I believe this info may be found in your owners manual.
Did the main step 1 & 2, then,
There was no chime. I pressed unlock once and the lights inside the cab went on - no door unlock, pressed the unlock again and then doors (both) unlocked. Tried again to be sure that on single press the light comes on and on the next press the doors unlock.
So I guess that's it for a 99. The instruction in the owners manual only speaks on turning the chirp upon locking off or on.
Any ideas?
I think the single click to open drivers door is desirable, Wifeymobile works this way (01 XC-70).
