Engine/Transmission (1998.5 - 2002) automatic trans fluid
Engine/Transmission (1998.5 - 2002) Air Flow-How much needed CFM
2nd Gen Non-Engine/Transmission Key in Ignition Chime - How to Disable?
trans fluid lV
The problem I see with changing your fluid to any but the extortion of Mopar, is that it will void ANY warrantee you have!! Unfortunately,hic, I still have some many miles on mine. If I change, I'm on my own. Can't afford that!! I hate the shudder I'm getting more and more from my TQ, but what can you do?? When it finally goes, or loosens all the bolts holding the truck together, at least back it will go to the dealer!! Isn't it a shame when you kind of wish you didn't have a warrantee so you could 'fix' it yourself? My Chrysler 300 has the same problem, same oil!! Kind of wish I had stuck with Ford. At least they use regular fluids you can buy at NAPA!! ACHTUNG!!
