I am about to install my transmission temp sender in the cooling lines. My truck with automatic transmission runs the transmission fluid thru a coolant cooler under the exhaust manifold and then to an air cooler up in front of the radiator.
My problem is, although I have the big 3 inch service manual, nowhere does it identify the lines. I want to measure the hottest point of course, but I don't know which way the fluid runs! Does it go thru the coolant first then the air, or the other way around? Or which line on the transmission is the "out to cooler" line and which is the return?
