Anyone know the part # / cost of an APPS in another ISB 24V application? Since it hooks directly to the ECM I would have to believe it would work (maybe with minor tweaking). If Cummins has one that physically looks the same & is relatively cheap < $50 I would be tempted to get it, apply the same voltages as go into the "dodge" version and see what the outputs are on it. If they are the same the bingo - done. If not then maybe have to add some resistors or to get it "right".
Thoughts?
FYI:
the connections to the ECM from the APPS:
APPS ECM
1 >--------BK/LB--------< 11 (B+)
2 >--------LG/DB--------< 16 (Idle Val. Switch 2)
6 >--------BR/OR--------< 1 (Idle Val. Switch 1)
4 >--------BK/YL--------< 32 (APPS Sensor Ground)
3 >--------LB/BK--------< 25 (APPS Sensor Signal)
5 >--------DB/WT--------< 31 (APPS Sensor Supply)
I seem to be having a touchy throttle at a certain position (surging at that position). I am going to try to validate the problem by putting my meter on the sensor signal and see what it is doing when it surges. Sure wish I had an ODB tool to watch throttle value, but the meter will work.
Thoughts?
FYI:
APPS ECM
