Re: What happens???
Originally posted by BHaner
What happens when the main tank gets full? Does it start going everywhere?
Are you putting the line into the small hose on the filler neck or the main tank vent?
I have a chevy 20 gal tank with three hoses (supply, return and vent) if i hook my main vent to the supply of the chevy tank will it suck it down with out a pump?
1. It doesn't overflow, when gravity feeding, as the top of the regular filler neck is above the bottom of the aux tank. NOTE: If you have an aux tank bigger then the main tank, then it may overflow, as the level in the aux tank may be above the main tank, when the main is full. I have a 37 gal aux tank and only tranfer when the main is almost empty, or I have to watch it fill to make sure it doesn't overflow.
2. You just "T" into the vent line off the filler neck.
3. Yes, you can run a tank vent from one tank to the other, but I just kept it as simple as possible. I gravity feed my aux tank when I've stopped somewhere (to eat, camp, etc) and let it fill.
The reason you have to loosen the filler caps, for this type of installation, is that the caps only vent in one direction, into the tank, and will not vent to the outside. If you don't loosen the caps it will not flow, or at least you don't want to wait around for it to trickle in...
