I'm installing an aux trans cooler aft of the transmission, removing the oil to water ( which is actually a heater, cause when I removed the water lines, I had to drive 300 miles and noticed my trans fluid never got above a 110 * ) anyway, the steel ines are bent fwd to accommodate the OTW cooling lines, and I don't want to loop the rubber hoses to point aft, so I was wondering if anybody has ever used copper line to replace the steel return line, I think it may be easier to use copper, ( easier to find also) it only needs to be about 24" long to go from return on trans and across to passenger side, then bent aft, Also does anyone know what size the fitting is ( Flare nut ? ) on the return line @ the transmission ?
