Is anybody running an auxiliary fuel filter ? What kind is it and how did you mount it are there any options besides the fass or air dog system
IF your filters are good on your pump, you need to keep an eye on your truck... sounds like someone has tried to sabotage it.... Shouldn't any sand be making it in there, unless you got it at the Sinclair station, which I guess is possible....
On a side note, those are neat old pumps, darn near bulletproof....
That's from your fuel.... Where are you filling up? Odd it's making it past the pickup filters below the lift pump.....
As for an aux filter, there are a ton of options out there. Personally, I'd run something like the FS1212 Fleetguard fuel filter. Basically the same filter you'd get on an Airdog/Fass. Fleetguard Fuel Filter Head 142784S for the FS1212 filter. Mount that up on the frame in front of the tank and change every 5K if you find some trash like you're describing. Maybe 10k once it cleans up.
Use two heads for a dual water separator and fuel filter setup.....
