MerCruiser years back was having some issues with their Bravo series outdrive's clutch system not lasting. They had copied Volvo Penta's system as soon as the patent ran out only they chose to use a different metal for the clutchcone asy to save money. They had been using 90 wt gear lube in everything up until that point. Not wanting to redesign the clutch they started to look into additives for the lube oil. In the end they came up with their own blend that not only solved their clutch failure issue but also made gear sets last almost double their life. Proven in MerCruiser's own test cells and on Lake X in Fla.
My point here is while I'm sure that the internal parts on our BW transfer cases are very much the same as the NP units just by chance BW like MerCruiser has come up with a Gear lube that allows the unit to last longer. For the 2 qts needed I think it it's worth the cost. Think about it the truck you bought cost up words of $50-$80K you are going to cheap out on the products that make it work day in and day out. [/QUOTE
The difference being, Merc built the unit, developed the lube and then made the recommendation( or requirement for warranty) Borg Warner built our transfer cases but flat out refuses to even recommend a particular fluid. Now look at Aisin. They build our trans and put a sticker right on the transmission that gives the fluid requirements. They don’t require Mopar fluid, but a fluid that meets JWS 3309 specs. FCA does the same with their transmissions, requiring atf+4. Any required fluid has a spec to meet, and it’s listed in API specs that can then be met and produced under licensing agreements. They recommend Mopar, but any ATF+4 meets warranty requirements.
