Originally posted by CChaney
Pack the bearings with grease it takes a little while to get the gear oil out to the bearings and you will beglad you packed them.
It cant hurt and the spindle is part of your housing so if you fry a bearing you also bought a new rear end.
I know the bearing are lubed by the rear end fluid but it can't hurt to add grease as you suggest. I was going th pour rear end lube over the bearings but I'll feel better with a little grease on them. Thanks
