Axle shaft hub nut size???
ford stink?
BFG AT KO 285/70R17 E Rated
I need to replace front axle shaft u-joint 1st thing in morning and I want to be ready, Dose any one know what size the axle shaft nut is?
Thank You
Thank You rbattelle,
I am done, It was a struggle but I am done w/ the rite side, I had a problem w/ the u-joint from NAPA it was a Chines pice of SH** that did not fit in the yoke the center section had too much girth. I got a MADE IN THE USA one and the job went together smoothly 9 houris later.
Thanks for the trend link, the 06 was 10 times harder than my 98 everything was SEZED.
