rbattelle
The January 2005 issue (isn't it only November?) of Four Wheeler has a nice table of strength ratings for some common axles. I didn't scan it as an image because I'm not entirely sure how copyrighting works and whether I'm allowed to scan a magazine image and post it here.
Anyway, the data for the axles we're interested in is (MOT is max output torque, COT is continuout output torque):
AAM 9. 25 Front - 4663 ft-lb MOT (no COT given)
AAM/GM 10. 5 FF Rear - 6242 ft-lb MOT (no COT given)
AAM/GM 11. 5 FF Rear - 8321 ft-lb MOT (no COT given)
Dana 60 Front - 5550 ft-lb MOT (1500 COT)
Dana 70 HD Rear - 8800 ft-lb MOT (2000 COT)
Dana 80 Rear - 10000 ft-lb MOT (2500 COT)
Ford 10. 25 FF Rear - 8300 MOT (2000 COT)
Ford 10. 5 FF Rear - 10660 MOT (2900 COT)
There are some interesting things in this data. First of all, none of the AAM axles had a COT rating. I take that to mean that the COT and MOT for AAM axles is the same (they are rated for continuous maximum torque output). If that's true it would be VERY impressive given how much lower the COT ratings are for every other axle in the list. Second, the list indicates the AAM 11. 5 inch rear is weaker than the Dana 80 and the Ford 10. 5 inch rear. I had been operating under the assumption that the 11. 5 was at least as strong as the Dana 80. Third, in the table in the magazine there's a little "+" next to the AAM 11. 5 and 10. 5 rear ends that, according to a footnote, indicates that higher-rated versions of these axles are available from the manufacturer. Perhaps we have higher rated versions on our trucks?
-Ryan
P. S. FF means "Full Floating". "Full Floating" means the axle shafts don't carry any of the vehicle weight. (I think... someone correct me if I'm wrong please!).
-Ryan
