AYellow fog lights QUESTION
coolant level
Tool batt charging
why aren't the fog lights yellow??? yellow cuts through fog, snow better than white light DoHHHH!!! can one switch them out, without freaking out the electrical system ?? for yellow lights! Any thoughts or suggestions. Much appreciated !!!
Because they're driving lights, not fog lights. Aside from the color difference, a fog lense is more of a flood pattern than a driving lense to reduce reflection from the fog.
I've seen two trucks locally that have installed yellow bulbs in the driving lights. I'll see if I can catch one and see what they did m
If you shop around on line you can find yellow tint bulbs that should be a direct replacement. I'll try and look around a bit when I can and post what I find.
What year is your truck?
Search on Amazon for these...
Optilux H71071112 XY Series H10 12V/42W Xenon Yellow Halogen Bulb Set.
Optilux H71070602 XY Series HB4/9006 12V/55W Xenon Yellow Halogen Bulb Set
I'm not sure which bulbs you have, 9006 or 9145. Either way you can find them there. :)
