GrantP
AZ (and a couple of other states I believe) require a diesel emissions test which basically amounts to flooring the throttle from idle while they check for smoke. I will be tightening up the star wheel prior to the test so I'm not concerned about the actual emissions output. What does scare me is the 3k GSK. How high will the engine rev in park and full throttle? If memory serves, you have to maintain full throttle for 15 seconds or so and do this multiple times all while someone is watching over your shoulder presumably to make sure that your actually flooring it and that the engine is not exceeding "redline" (as the tester put it). This test was not a problem when stock, the engine stayed right at 3k rpm, but where will it stop now with the 3k governor springs? Before I go out to the driveway and try it, I'd love to hear from anyone else that has to endure similarly retarded emissions testing with a 3k GSK. If it does rev much higher than 3k, any suggestions as to how to temporarily "limit" the RPM's during the test? Thanks in advance.
