I just installed my B&W Companion hitch but need some advice. When the hitch is torqued down to the pin it doesn't contact the box at the back of the support plate and has about 1/4" clearance. The bottom of my box is hammered down a bit between the supports from hauling wood, sleds, quads, steel etc. I think I should put some shims say some 4"x4"x1/4" steel plate under the back each side of the hitch. What do you other companion hitch owners think?
Mike
Mike
