I installed my B&W hitch, with the Companion 5th Wheel adaptor, over a year ago. I have been very pleased with this setup, but I wanted to pass on a couple of areas to see if others have experienced this.
First. Hitching and unhitching go very smoothly except for the following circumstance. I recently pulled into a site that was not level from side to side (3-4" off level). I pulled the trailer up onto levelers and the hitch would not release. I ended up releasing the head (using the two pins that hold the head to the base) and releasing it that way.
Second: I have used a "lube plate" on my hitch, in the past, to avoid having to use grease on the hitch head and kingpin flatplate. With a standard plate, from camping world, the hitch will not engage even on level ground.
I emailed B&W and here is what they said: The locking jaws are thicker then standard hitches. This provides more strength and also helps prevent movement of the kingpin when locked up.
I can live without the lubeplate, but I don't like the problem of not releasing when not level side to side. I still feel that this is a superior hitch, compared to the hitches I've used in the past, but just thought I'd throw this out for others to comment on...
