ALLOT... ... . remember the 40 uses the internal gate so it's up against the manifold and that mixed with the reverse rotation it's real hard to make it fit in that hole, a 3B can be stuffed under the manifold as you know. The trick is to make the hot pipe long enough and have the right kick out on the bottom of the pipe, meaning it doesn't hang straight down under the top turbo, mine has some but when it was done I still had to egg the frame just a tad so the compressor housing wouldn't hit under acceleration.
I had the 40's housing, hot pipe and B/B in and out 8 times... ... what a pain, no way would I ever build Twins like that for a living.
Jim
