AH64ID
I have never heard the HE351 will support lower hp on a 1st gen. Its a 35psi turbo, so it will support whatever 35psi will cool for you.
The housing is smaller than most, but I have also read that the housing on the HE351 is a hi-flow version, or the 9cm on it would be similar to a 12cm from the 90's.
If you incorporate a WG into the HE351 at about 35psi you should have no DP issues. As long as I'm not WOT above 2700 rpms my DP isn't crazy, and thats on a 3rd gen head with a cam, which moves a lot more air than a 12V.
