Just to give a better idea of the combustion process in a stnadard DI engine under standard timing, taken from Int Comb Fundamentals by J. Heywood.
"Figure 10-4 shows a cumbustion sequence from the DI engine with swirl. The inner circle corresponds to the deep bowl in the piston crown, the outer cicle to the cylinder liner. THe fuel sprays first appear at -13deg (btdc). At -7deg (btdc) they have reached the wall of the bowl; the tips of the sprays have been deflected slightly by the anticlockwise swirl. The frame at -3deg (btdc) shows the first ignition. Bright luminous flame zones are visable , one on each spray. Out by the bowl walls, where fuel vapor has been blown around by the swirl, larger greenish burning regions indicating the presence of premixed flame can be seen. The fuel downstream of each spray is next to ignite, buring yellow-white due to the soot formed by the richer mixture. Flame propagation back to the injector follows extremely rapidly and at tdc the bowl is filled with flame. At 5deg (atdc) the flame spreads out over the piston crown toward the cylinder wall due to combution -produced gas expansion and the reverese squish flow. The brown regions, 13deg (atdc), are soot-laden fuel-rich mixture originating from the fuel which impinges on the wall. The last frame, 30deg (atdc), shows the gradual diminution of the soot-particle-laden regions as they mix with the excess air and burn up. The last dull-red flame visible on the fiulm is at about 75deg (atdc), well into the expansion (power) stroke. "
To me it sounds like the problem is incorrect timing, maybe the timing is slightly delayed, combined with the cold engine engine quencing the heat of the combustion causing incomplete combustion that may or may not cause the cylinder to missfire (thud or knock), and the combustion may still be happening when the exhaust valve opens causing you to hear it out the exhaust.
I do not think it would be advanced timing for this problem, becuase then the cylinder pressures are greatly increased which can help combustion (and power) but can lead to knock (rattle) easily. Most of the older injection pumps have a mechanical timing advance for cold weather.
