Or you can buy this one......with 3 cameras!
Rear View Camera System with Side Cameras Model # RVS-770616 - Products
OR the 4 Camera Version... ... ... ... .
Rear View Quad Camera System # RVS-7707100 - Products
* High Resolution COLOR CCD Video Rear View Camera with Built-In Infrared Illuminators & Microphone
* TWO High Resolution COLOR CCD Video Side View Cameras w/ Built-In Infrared Illuminators
* High Resolution 7" COLOR TFT-LCD Wide Screen Digital Video Monitor, Built-In Speaker, FOUR Camera Automatic & Manual Selection (all three cameras are included)
* ALL FOUR cameras can be controlled automatically via your vehicle‘s backup lights and turn signals, and all cameras can also be switched manually at any time
* Full Function Wireless Remote Control
* FOUR 50' Foot Power/Video/Audio Cables w/ Weatherproof Stainless Steel Aircraft Grade Connectors
* Flat Surface / In-Dash & Heavy Duty Universal Adjustable Monitor Mounts
* Monitor Can Be Mounted on the Dashboard, Sun Visor, Center Console, Windshield, Hung From the Ceiling, or Almost Anywhere Else
* Adjustable Heavy Duty Powder Coated Steel Primary Camera Bracket
* Main Power Wiring Harness w/ Aircraft Grade Locking Connectors & Simple 3, 4 or 5 Wire Installation
* Miscellaneous Cables, Mounting Brackets & Hardware
* User Manual w/ Simple Do-It-Yourself Installation Instructions
Rear Camera Specifications:
* Highest quality COLOR CCD video camera available
* Highest resolution 1/3" Sharp® CCD image sensor
* 120 degree wide angle precision micro lens
* Selectable on / off ‘mirror image‘ function
* 18 high intensity infrared night vision illuminators
* Vision in night range up to 50 feet in total darkness
* Aircraft grade stainless steel weatherproof connectors
* 420 lines resolution (512 x 492 pixels)
* NTSC (North American) format camera
* 1 inch to infinity fixed focal range
* Built-in high gain microphone
* 6. 8 G-force rated shock resistant
* Heavy duty adjustable powder coated steel mounting bracket
* Black weatherproof powder coated aluminum camera enclosure
* Dimensions: 3. 75" (w) x 2. 0" (h) x 3. 0" (d)
Side Camera Specifications:
* 9 high intensity infrared night vision illuminators
* Night vision range up to 50 feet in total darkness
* NTSC (North American) format cameras
* Black heavy duty weatherproof camera enclosure (can be painted to match vehicle)
* Dimensions: 4. 25" (w) x 4. 25" (h) x 2. 25" (d)
Monitor Specifications:
* Highest quality 7" COLOR TFT-LCD wide screen digital Quad video monitor with illuminated controls
* Illuminated control buttons light automatically during darkness
* Automatic and manual 4 camera switching capabilities
* Shock resistant, designed specifically for mobile use
* Super sharp picture with 1440 (h) x 234 (v) resolution
* 0. 107 (h) x 0. 372 (v) dot pitch, 150:1 contrast, 300cd/m2 brightness
* 15° (up), 35° (down), 55° (left/right) maximum viewable monitor offset
* 4 camera selection (all three cameras are included)
* Includes flat surface / in-dash and heavy duty universal mounts
* Optional windshield suction mount (see available options below)
* Individual selectable (on / off) horizontal ‘mirror image‘ function for each camera
* Selectable (up / down) vertical ‘image flip‘ function
* Full function wireless remote control
* Optional RCA inputs available for audio / video equipment
* NTSC and PAL format compatible monitor
* Black high impact monitor enclosure
* Built-in audio speaker included
* Includes removable sunshield
* Dimensions: 7. 2" (w) x 4. 8" (h) x 1" (d)
Package is complete with:
* 2 Color CCD side cameras w/infra-red weather proof camera
* 2 Color CCD camera w/infra-red weather proof camera
* 1 7" TFT LCD Quad color monitor with universal mount/stand and wire
* 4 50' extension cable for camera
* 1 Remote control
* 1 Power connection wire
* 1 Double RCA + power converter, (to connect external, audio video and power)
* 1 Screw kit for installation
