Prairie Dog said:
Prairie Dog said:I rolled my eyes because you seemed to be getting upset just because we have a difference of opinion ~ there seems to be a lot of that here lately. This is just the first time I've been subjected to it. Sorry to have offended you.
I believe a redundant relay isn't needed. I arrive at this decision do to the experience and schooling I have. You have a different opinion based on the same. Either way will work fine and wont result in any heartache.
Your "Pal"
Scotty
Prairie Dog said:Well... I guess I don't mind eating a little crow if it will benefit my TDR brethren.
It turns out the TIPM (totaly intergraded power module) will see these larger lamps as an overload and it will count each time their turned on as an incident. After a specific number of incidents (maybe 250), it will shut down the circuit (all b/u lamps). Then it has to go to a dealer to have the DTC cleared from the TIPM computer, it may even require a reflash. This goes for all the lighting circuits in the 7 pin connector.
Here's the ugly part, you can only clear these codes 5 times before the TIPM has to be replaced @ $300+.
I don't know if this includes the earlier third gens but the 06 is built this way.
Thanks to sag2 for all the great inside info (as usual).
Scotty
PAllyn said:55watts should pull less than 3 amps. Its Okay![]()
Prairie Dog said:Bob, the trailer circuit is affected by this. It looks like anything more than a couple of 7 watt lights will cause this problem. I strongly recommend anybody running big lights disconnect them ASAP and rewire using a relay.
rbattle, thanks for the compliment but my wife has made me an expert at admitting when I'm wrong so it comes pretty easy:-laf
