try to see if there is a fuse for it, then work your way back, I see you have a 6 speed, you might want to see if the power is going through the switch at the transmission, then work your way back to the lights themselves. use a test light , if all else fails and you are still scratching your head, then to the dealer you go.....
Hope you find the problem,
Eric
