I am in the planning stages of building an ice rink in my yard. Well not really my yard, but a flat spot in the trees (once I cut them down and flatten out the spot). I know I can not be the only guy on here who is or has built a backyard ice rink. Share your tricks and tips with me. What kind of liner did you use, what kind of base under the liner? How big was it?
The current plan is too build a rink that will end up being about 24x24 ft. I am going to flatten out the spot (I get to rent a bobcat. . woo woo) and then build side boards out of treated 2x8's (or 2x10's depending on how level I get the spot). I am going to put either sand (hard to keep cats out of in summer) or pea gravel in it and lay a white liner in the hole. Then come winter and cold weather I will flood the liner with water and bingo my little boys will have there own rink. I also plan on installing flood lights and a burn barrel for warming up little hands.
What do you think??
What do you think??
