Lifts are for gassers:-laf:-laf !
HTML:that is plain u-joint alignment, not the sine waves and loads
Same thing.
Stacks are for semi's, Dyno's are for drag cars anything else I should go agianst the grain on?:-laf
Having u joints out of phase, or alignment would be the same as having the angles wrong, as the joints being in phase and in the correct angles cancel out each other. If they are not phased roght, they can't cancel each other out. One thing I don't understand, is both of my unmolested dodges the pinion pointed right at the output of the transfer case, and the rearmost joint has little or no angle to it, and that was factory.
Michael
