Superdawg
I should have left it alone..... After recent install of Bosch Reman injectors, it runs pretty good. Years ago, I replaced the pressure relief valve and FCA chasing some engine issue.
I thought I would swap those pieces back in to see if it would run any smoother. I unplugged the FCA and attempted to remove it but I had tightened the screws down so tight last time I dinged the head of one up. I snugged it back up and swapped out the pressure relief valve with the one that was in there.
I started it up and it ran rough. I put my the other pressure relief valve back in and it still ran rough.
I then realized I did not plug the FCA in. I plugged it in and it still runs rough. No difference in plugging the FCA in or not plugged in. Very rough.
Bad FCA that just gave up the ghost when i started monkeying with the system?
Did I introduce air into the system changing the pressure relief valve that has to work itself out?
thanks,
Tom
thanks,
Tom
