Vaughn MacKenzie
For quite some time there has been a popping/snapping sensation emanating through the steering under some conditions and it has gotten much worse over the last few months. It mainly does it when accelerating, the moment I let out the clutch to take off, and it does it when turning slowly on uneven surfaces such as pulling into a parking lot. Also, I occasionally hear a sharp "crack!" sound originating around the cowl or under the back side of the dash. The odd thing is, some days I barely feel any of this and the next day it will be really bad. Steering otherwise is perfect, linear, smooth and tracks straight.
The last few days I've heard really bad grating, grinding noises coming from the back side of the dash. Also driving with the window down I heard a grating sqeak accompanying the pop felt through the steering wheel.
I jacked up the front end and torqued on the tires in all directions and everything is tight as can be, no evidence of balljoint problems or with the steering linkage.
Next plan is to remove the fender on the driver's side and look for broken welds. I heard of this in a post several months ago. While I have a 2wd truck I have off-roaded with it pretty hard quite a few times in the mountains and taken several axle-busting, bonejarring roads.
Any suggestions or ideas shoot 'em at me. Anyone know how much work is involved in a fender removal??
Vaughn
Vaughn
