bad fuel milage
Exhaust Question?
Used motor???
i have a 92 250 w/3:54s. my fuel milage was 17/18 when i got the truck but since last winter i have only got 14/15. i change fuel and air filters regularly. the only things i have changed is 16cm2 housing,4 inch exhaust, bd exhaust brake. i watched the boost and it goes to about 25 psi but i have higher egts then my cousin's 95, : mine runs about 700 at 60 mph. the only fuel increase was when i got it and it still got 17/18 mpg. so if any ideas is greatly appreciated. and it has not lost any power.
fuel cleaner did not help. :
bs
Howdy, I'm in the same boat except that it's always been bad. I got the same EGT's about 700 at 60. I have seen 1200 a couple of times on 9% grades at 32psi and 22,000lbs gross.
mpg drop
Make sure that your front brakes are not draging... If the calipers still have the plastic pinstons in them . Replace them with steel pistons ... .
bs
