BDaugherty
Driving home from work yesterday, my attitude monitor started to chirp at me and flash "oil pressure 0 psi". The gauge on the dash was right in the middle (40 psi). After 5-10 seconds, my attitude monitor read 99 psi. 20 minutes later, it started working normally... reading about 60-65psi at cruising speed. When I got home, I checked all of the preliminary stuff. Oil level was 2 hairs below full, connection to oil psi sensor clean, dry, and secure. This morning, when I started the truck, the attitude showed 0 psi for the first 20 seconds and then went back to 99 psi. About a mile from the end of my 33 mile commute, it started to read normally again. After work today, I started my truck and it went straight to 99 psi. I had a buddy watch the attitude monitor while I wiggled the sensor wiring and even unplugged it. The attitude read 99 psi the whole time. I really feel like it's a bad sensor, but the cheapest one I've found is $175 @ RockAuto and I just don't have the money to throw parts it it. If I can be 100% certain that the sensor is bad, I'll order one right away. I haven't had any MIL lights and the gauge in the dash seems to function sort of normally... but it's really hard to tell since the ECM limits the functionality of the gauge in the dash.
Does anyone have any advice or input on what I should do? I might be able to swap sensors with a buddy's truck this weekend, but I'm not 100% that his sensor is good.
