Bad Steering Boxes???
Mega vs long bed.
2013 Dodge Ram CTD
In reading the newest issue of TDR, I see that there is yet more being mentioned about the steering boxes! I find it funny that so much discussion goes into this subject! I have 140,000+ on my 2003 HD SRW and I have not noticed any change in the steering. I can go down the road a 70+ pulling a trailer or not, take my hands off the wheel and that truck drives as stright as can be. I am never sawing on the wheel as some seem to suggest that they are doing. This just doesn't make any sense that so many people are having that much problem, or are there actually that many people?? :confused:
I know both of my sons have had issues with their dodge trucks with the steering. My youngest son had a 1997, 2500 Reg Cab Sport truck with the V-10 engine, 4X4. Truck drove good and had no issues in the first 30k miles will he listened to his older brother and he installed over size tires and lifted the truck. Guess what he now had steering issues about 10 k miles later and the steering would wander on the road and had the death wobble.
Now my older son's 2006, Crew Cab 2500HD 4X4 Cummins engine was fine also as new; but once he lifted the truck and put oversize tires and rims on will he had steering issues. He beefed up the steering box support and uses a heavy duty steering damper; the steering is back to normal.
My opinion is that most of the problems on the straight axle 4X4 trucks is caused by the owners lifting the trucks and using oversize tires and rims on their trucks. This has been a common problem since I owned my first 4X4 truck as far back as 1973 with my AMC Jeep Cherokee (full size). If you installed oversize tires and rims this would be an issues and then when you lifted the vehicle it became worst.
The manufactures design their vehicles around stock specifications and not for aftermarket equipment. If you install aftermarket equipment you do run the risk of that component or system not performing as designed. This may not be all of the issues with the steering but I do think it will account for most of the problems.
Jim W.
I don't think you have a steering gear on your 2WD, I believe you have a rack and pinion.
My gear was sloppy when new and started leaking after just a few thousand miles. Dodge replaced it and its been fine ever since.
