We at Dynomite Diesel are proud to announce the arrival of our Extrude Hone machine. This machine is very unique, and will give us the ability to balance your injectors, so that they flow the same. Matching your injectors will help your truck run and idle smoother, while increasing performance. The same technology recently helped the fastest 4x4 get into the low 10’s. Also Piers from PDR just made 685hp on our DynoJet, with our injectors, a TST Box, a PPE box, medium sized compounds and a cam on his 04. 5 common rail.
Until the end of February we will be offering substantially reduced prices on our custom injectors. You can send in the whole injector, or just the nozzle. Extra charges will apply to anything that is not just a nozzle, for disassembly cleaning, and the adjustment of opening pressures.
The horsepower level is up to you. These will be custom which means you tell up HP level you are trying to achieve, but, we will help you decide what is within the limits of your current modifications
As I said these are extremely low prices, that will probably go up by 4 or 5 times at the end of February. I wish I could let you all know, but this section of the TDR does not allow pricing info. We do have a waiting list, call soon to get on it so you do not miss out.
If you are in the area and have us do the work on your truck and injectors, we can offer you a dyno run before and after to show you what gains have been made.
Please give Ross call at 360-794-7974.
Ross Fahlen
Dynomite Diesel Performance
Ross Fahlen
